tire clearance
Old Feb 22, 2007 | 08:16 PM
revjchacker's Avatar
revjchacker
Default tire clearance
Just bought my O3 Dak two weeks ago. As I have been backing out of my parking spot, I've noticed a grinding sort of noise from the passenger front. I was really trying to figure it out and then last night I did. The tire is rubbing the mudflap and not even close to full lock, it's actually only at about half turn. I did some measuring and noticed that the clearance of the two front wheels to the back fender is quite different. I called the dealer I got it from and they're going to look at it. The upper ball joints were replaced in the recall, I assume the alignment was done after. Is there anything else that would cause the wheels to be so off kilter besides alignment or joints? (btw no noticable aligment issues, she drives as straight as an arrow) I just want to be ready for the dealer on Tuesday. I don't like these guys very much but have to have it there for the used car warrenty.
Old Feb 22, 2007 | 08:21 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: tire clearance
what size tires do you have on there? and is it 2wd or 4x4?
Old Feb 22, 2007 | 08:24 PM
revjchacker
4X4. The 16/265s that came on the truck new. Only 38,000 so far.
Old Feb 22, 2007 | 09:05 PM
Chris's Avatar
Chris
Sounds like your upper control arm linkage is loose.
