Recalls
Old Feb 24, 2007 | 03:39 AM
jakebank's Avatar
jakebank
Default Recalls
This might be a dumb question but how do I find out if the previous owner of my truck had taken care of the recalls for this truck. Its a 2002 Dakota SportQC 4.7 4x4 Auto. I know the guy babied this truck and it was in immaculate condition when I bought it. I bought it in June and haven't had any problems yet (knock on wood) except for a power window breaking b/c it froze up. So is there a way I can find out if the recalls have been taken care of on this truck.
Old Feb 24, 2007 | 03:59 PM
red9535's Avatar
red9535
Default RE: Recalls
Umm find out what recals there were for that model, then check them?
lol
What do you want us to say? Either ask him, or find out what they are then check them yourself. If you find any specific ones you want to check, but dont know how, then post THAT and we'll be able to help
Old Feb 24, 2007 | 04:12 PM
imnothot02's Avatar
imnothot02
Default RE: Recalls
with the VIN#
Old Feb 24, 2007 | 04:33 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: Recalls
http://www.dodge.com/owners/index.htmlHere is the link from the dodge site. Just type in the last 8 numbers of your vin where it says to and it will show you any recalls that haven't been performed on your truck yet.
Old Feb 26, 2007 | 12:08 PM
01dakota's Avatar
01dakota
Default RE: Recalls
ORIGINAL: red9535
lol
This is a legit question man, dont be a dick.
You can either call or stop buy and dodge dealer, give them your vin and they will tell you where the truck was originally purchased, all the options your truck came with, all the recalls for that truck and if they were ever taken care of. There is no charge for this. I didn't try the link posted above but that may work the same way. I think it's better if you stoo in though because they will give you a print out of everything. You may have to ask for the pritout of all your options though.
Old Feb 26, 2007 | 02:02 PM
jakebank's Avatar
jakebank
Default RE: Recalls
Yeah I just found out the ball joints need to be done. I went through that link and it said that recall is imcomplete so I called the dealer the truck was originally purchased from and they said they can do it Friday so that is good. Thanks for all the info. Also does anyone know if an alignment needs to be peformed after the ball joints are fixed?
Old Feb 26, 2007 | 02:44 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Recalls
yes you'll need an alignment and you'll probly have to pay for it too, I dont think they cover that under the recall.
Old Feb 26, 2007 | 07:36 PM
2000Dakotadriver's Avatar
2000Dakotadriver
Default RE: Recalls
I didnt know about that site. I found out that my clockspring needs to be done. That would explain the grinding behind the steering wheel when turning.
Old Feb 26, 2007 | 08:15 PM
Chris's Avatar
Chris
Default RE: Recalls
You might not need an alignment. If the Dodge service tech knows what he is doing, you shouldn't need one. They are only replacing the upper ball joint; not servicing or adjusting any other suspension component. You should be fine. However, if for some reason you begin to develop unusual tread wear, you know the guy was an idiot and turned your tie rods around or something. Put it this way, do you need an alignment after the upper ball joints are replaced? Probably not, but if you don't do the work yourself, you will never know what other suspension component was altered. Jonny is probably right to suggest getting an alignment, but in theory, nothing effecting alignment would have been changed.
Also, I would suggest going with the greasable ball joints.
Old Feb 26, 2007 | 09:01 PM
jakebank's Avatar
jakebank
Default RE: Recalls
Good deal thanks for all the good info
