Poor braking
Old Mar 4, 2007 | 06:19 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: Poor braking
my dads 96 dakota had 120,000 on it and was still on the origional pads and rotors in front, but his was because he does like 35 miles one way to work on the highway each day so that helped
Old May 29, 2007 | 08:48 PM
dskup's Avatar
dskup
Default RE: Poor braking- squishy brake syndrome
I'm having the same problem this guy originally posted. I wish he would have followed up with the fix. I will start by servicing the back brakes, as suggested. But I suspect the master cylinder is going. When sitting in the driveway, or sitting at a light for a spell, the brake pedal sinks to the floor. After driving fast, the brake pressure returns. ANY NEW IDEAS ON THIS?
Old Jun 14, 2007 | 05:32 PM
brocksyoda's Avatar
brocksyoda
how goes it? Did you ever find a solution to your brake troubles? Im having exactly the same problem. I lose the pedel while stoped. Ive bled the lines, no help.
Old Jul 6, 2007 | 11:52 PM
PJS400's Avatar
PJS400
Still no solution. Will probably replace the rear shoes. I suspect it's the booster though. Pedal doesn't sink while sitting, just not enough power to stop fast/lock brakes.
Old Sep 30, 2007 | 12:20 AM
PJS400's Avatar
PJS400
Just to close the loop here....turns out the front calipers were frozen. Only rear brakes were working.
Old Sep 30, 2007 | 01:54 AM
imnothot02's Avatar
imnothot02
so dont wait 120000 miles to do a brake job ehh ?
Old Oct 23, 2007 | 11:51 AM
BigRedLemon's Avatar
BigRedLemon
I'm having this problem too. The bad thing is it's happening post-brake job. I just got new shoes/pads/rotors/drums and I have to stand on my pedal to come to a gradual stop. Never go to Midas!!!
Old Oct 23, 2007 | 12:10 PM
steve05ram360's Avatar
steve05ram360
take it back and have them fix it. most likely air in the lines. what I'd recommend is going and getting some synthetic brake fluid and have them flush the lines with it.
