Leak
Old Feb 28, 2007 | 04:29 PM
98Dodger4x4's Avatar
98Dodger4x4
Default Leak
Well I drive to work today and park go in after a hour. A co worker told me im leaking anti freeze I look under the truck and can't see anything. Well I take it home and park it go in he house eat lunch come out and don't see any water leaking any where. IM thinking the water pump may be leaking a little any ideas?
Old Feb 28, 2007 | 04:40 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Leak
or....... your co worker was smoking something[sm=pimp.gif]
do you smell anitfreeze at all?
Old Feb 28, 2007 | 04:53 PM
Casper50's Avatar
Casper50
Default RE: Leak
Does your overflow hose run to a tank or to the ground.If it runs to the ground that's the only thing I can think of if it's not leaking anymore. If it goes to a tank then I'm with jonnymagnum that your co-worker is smoking some good stuff and isn't sharing!!
Old Feb 28, 2007 | 04:58 PM
98Dodger4x4
Default RE: Leak
its runs to the tank. I do smell anti frezze now and then but not always. When thetruck runs it builds presser becuase after you drive it and it sits for a couple I go to remove the cap its its under presser. I think im going to check the holding tank for leaks first and the hose going to it.
Old Feb 28, 2007 | 05:21 PM
2000Dakotadriver's Avatar
2000Dakotadriver
Default RE: Leak
I think mine is doing that as well. When I park after driving for a bit I can smell anti-freeze but I can't see any anywhere under the hood or under the truck. Although I can only smell anti-freeze when it is summer.
Old Feb 28, 2007 | 09:02 PM
01dodgedriver's Avatar
01dodgedriver
Default RE: Leak
Get some one with a pressure tester to test for leaks
or you co worker saw condensation from the air condition, or there was a puddle under yor truck before you parked, or your co worker is smoking something
Old Feb 28, 2007 | 09:11 PM
Chris's Avatar
Chris
Default RE: Leak
I agree with 01. I bet it is condensation from the A/C system. If it is actually antifreeze, check to see if your heater core is leaking.
Old Feb 28, 2007 | 10:41 PM
98Dodger4x4
Default RE: Leak
ok the ac is on and it dont work. I hate ac and never fixxed the line. The leak is anti frezze and is green. I did degrease the whole motor and laid under truck and did that 2. Well next is to let her run and see if I see a new wet spot. I will do it Thursday and see what happens because its late and i been up for 24 hours
