Hub Nut?!?!
Old Mar 2, 2007 | 02:25 AM
Megamanjs's Avatar
Megamanjs
Default Hub Nut?!?!
Okay, i am new to the whole dodge wheel bearing thing. Things were easy on my mustang heck an $8 bearing and 10min and your good to go. Anyway, i am try to do the hub assembly on my 97 Dakota 2 wheel drive but i cannot get this Hub Nut off! I have gone trough 2 1/2" Ratchets trying to break this nut loose with a 6 foot breaker bar! Is there some special trick or something that i am missing?
Old Mar 2, 2007 | 11:59 AM
Megamanjs's Avatar
Megamanjs
Default RE: Hub Nut?!?!
Any ideas?
Old Mar 2, 2007 | 12:21 PM
imnothot02's Avatar
imnothot02
use a breaker bar...not a rachet
Old Mar 2, 2007 | 12:22 PM
imnothot02's Avatar
imnothot02
i once used a bottle jack to bust one loose, i dont recomend it but i had very limited resources wehre i was
Old Mar 2, 2007 | 12:24 PM
imnothot02's Avatar
imnothot02
haha one other thing that has worked for me is using a mini sledge on the breaker bar, best bet however is a big impact wrench
Old Mar 2, 2007 | 12:29 PM
imnothot02's Avatar
imnothot02
pick up some n force, or open and shut, or pb blaster...these will help breaki up the rust n force is the best...
Old Mar 3, 2007 | 12:31 AM
Megamanjs's Avatar
Megamanjs
That did it. Thanks for the Rust N Force idea, that and a 1/2 breaker bar and an 8 ft pole! Now that i have it off, where do i get a replacement nut since i cant re-use this this one?
Old Mar 3, 2007 | 01:04 AM
imnothot02's Avatar
imnothot02
at the auto parts store should be about 2-4 dollars BE SURE TO TORQUE EVERYTHING CORRECTLY
Old Mar 3, 2007 | 01:06 AM
Megamanjs's Avatar
Megamanjs
What are the torque specs? Sorry for all the questions...first Dodge!
Old Mar 3, 2007 | 06:13 AM
imnothot02's Avatar
imnothot02
if i remember rite 80 lbs...i don't have the book here you can ruin the new bearing by overtighteng it
