I got 2 codes for sensors. Can anyone help me?
Old Mar 2, 2007 | 09:30 AM
vibher's Avatar
vibher
Default I got 2 codes for sensors. Can anyone help me?
Hi. New here and really don't know to much about trucks. I have a 1998 Dodge Dakota with 41,000 on it. Automatic, 2 wheel drive. Check engine light came on. Got 2 codes. 1st-P0340 Camshaft position sensor A-Bank 1 circuit malfunction. 2nd-Exhaust gas temp. sensor circuit low (bank 1 sensor 1). Is this something a dealer has to fix? If so any idea on the cost? I have no idea what these are. I do know the exhaust is a little loud as I have some bad manifold bolts I guess they said. Is it bad to run with the bad bolts? Can it be causing this problem? Any help is appreciated.
Thanks, vibher [align=right][/align]
Old Mar 2, 2007 | 12:42 PM
imnothot02's Avatar
imnothot02
Default RE: I got 2 codes for sensors. Can anyone help me?
sounds like ya have two bad sensors to me, however i don't have experience in this area, normally a voltage to low is either the sensor or the wiring...
Old Mar 2, 2007 | 06:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the exhaust gas temp low code could be caused by a lose or missing o2 sensor i know my tuck threw one of those and all i did was put the sensor back in and erase the codes and it has not come back on
Old Mar 3, 2007 | 06:16 PM
vibher's Avatar
vibher
Started the car today and check engine went out. This has happened before when it has 3/4 tank of gas. Top it off and about 2-6 starts it goes off.
Old Mar 3, 2007 | 08:52 PM
imnothot02's Avatar
imnothot02
do you fuel with it on...if so dont, this will throw a cel also look at the o ring on the gas capcould be leaking do you hear a hiss when you take the cap off?is ur truck pre 2000? if so have the code pulled, guessin a p0456 or ah i cant rember...evap code
Old Mar 5, 2007 | 06:07 PM
Candakota02's Avatar
Candakota02
My light was on, had the o2 code. I checked around, put on a new gas cap and reset the engine light by disconnecting/reconnecting the negative terminal on the battery. Been OK for a week, I'll keep you posted if the light comes back on.
