1999 Dakota Upper Ball Joint Removal HELP!
Old Mar 2, 2007 | 04:11 PM
loudad's Avatar
loudad
Default 1999 Dakota Upper Ball Joint Removal HELP!
Help what is the best way to change upper ball joints on a 99 Dakota 2wd? I heard something like removing control arm?
Old Mar 2, 2007 | 04:19 PM
Chris's Avatar
Chris
Default RE: 1999 Dakota Upper Ball Joint Removal HELP!
When you remove the upper control arm, it will allow you to work on the ball joint in a much easier fashion, like on a work bench versus on the vehicle.
Old Mar 2, 2007 | 04:29 PM
loudad's Avatar
loudad
Thanks for responding How hard is it to remove control arm? Do I drill out rivets to replace ball joint or do you replace the control arm?
Old Mar 2, 2007 | 04:33 PM
imnothot02's Avatar
imnothot02
uhm what rivets, and no you don't replace the whole arm...
Old Mar 2, 2007 | 04:37 PM
jonnymagnum's Avatar
jonnymagnum
the stock BJ's are held on with rivets, you just need to grind them off. and you'll need a BJ socket too. and they just turn out. I didmine with them still on the truck. just watch out that it doesnt fall off the jackstands when your prying on he BJ's to get them out mine came close.
Old Mar 2, 2007 | 05:05 PM
Chris's Avatar
Chris
I would still suggest removing the upper control arms. It takes an additional 3 minutes and is well worth it to ensure an easy swap. However, you will need to get an alignment if you do not properly mark their original position before taking them off. As Jonny said, you will need to grind down the rivets and get a ball joint socket to remove them. Be very careful while removing tension from the spring. The slower the better.
Old Mar 3, 2007 | 09:36 PM
lohebrohe's Avatar
lohebrohe
ORIGINAL: jonnymagnum
does this apply to the 1997 upper arms too? Also what size socket should I get? Recently my right upper balljoint gave out on me.
Old Mar 3, 2007 | 09:55 PM
jonnymagnum
you have to buy a socket specifically for BJ's. and since it's a specialty tool, it's expensive. I think I got mine for like $50. but you can go to autozone and probly just rent a tool if your only gonna use it once. I've used mine more than enough time to pay for its self. and only the stock BJ's are riveted in, and if they are the stock ones. just grind the rivets off and clean all around the top of it off. then spray it with ALOT of release all or what ever you like to use. then hammer the socket on to the BJ and get a johnson bar and put a pipe on top of that. I used a 3' piece of exhaust pipe. and brake them loose. there on there tight so dont be afraid of a lil brute force.
Old Mar 3, 2007 | 10:09 PM
lohebrohe's Avatar
lohebrohe
damn sounds teadious. what's "release" and where can I get it?
Old Mar 3, 2007 | 10:13 PM
jonnymagnum
"realease all" is lubricant. I find it works the best. alot of people use PB blaster and nutz lube and so on.
