dakota tire size..Anyone?????
Old Mar 6, 2007 | 02:57 PM
drjgarage's Avatar
drjgarage
Default dakota tire size..Anyone?????
OK this has been asked many times without answer...so one more time. What size tire can be put on factory rims?? Now there are 245-70x16.
Old Mar 6, 2007 | 04:24 PM
batman13's Avatar
batman13
Default RE: dakota tire size..Anyone?????
I've got 31x10.5's but I've seen bigger,
wheel size dosen't affect tire height, just width
Old Mar 6, 2007 | 04:32 PM
Chris's Avatar
Chris
Going wider than 10.5 is not recommended.
Old Mar 6, 2007 | 04:33 PM
Chris's Avatar
Chris
^On a 15x7. 15x8 you can go wider. I currently run a 33x12.5 on a 15x8.
Old Mar 7, 2007 | 12:02 AM
redneck84dodge's Avatar
redneck84dodge
your factory rims are 16x8.5 they can handle a tire as big as 315 75 which is equivialent to a 33.5" tire but if you use that size tire you will need a 6" lift kit but on a stock dodge dakota you are able to run 265/75 tire without rubbing...
Old Mar 7, 2007 | 09:42 AM
98Dodger4x4's Avatar
98Dodger4x4
I have 31x10.5x15 on mine
Old Mar 7, 2007 | 01:16 PM
jk240sx's Avatar
jk240sx
I run 265/75/16. zero rubbing.
Old Mar 7, 2007 | 01:51 PM
Chris's Avatar
Chris
ORIGINAL: redneck84dodge
Different wheel options are different. Some OEM wheels come 15x8, 16x8 and 17x8 (IIRC the R/T wheels are 17x8, someone correct me if I am wrong.) Also, I don't believe that any wheels came from the factory with a width of 8.5.
Chris's Avatar
Chris
Also, some wheels came 15x7.
Old Mar 7, 2007 | 10:54 PM
imnothot02's Avatar
imnothot02
OHHHH so different trucks all use different size tires ehh! [:-]
