Emergency brake Seized, Warped Drum Brakes
Old Mar 14, 2007 | 04:37 PM
00 Dakota's Avatar
00 Dakota
Default Emergency brake Seized, Warped Drum Brakes
Anyone ever hear of this before?
My 2000 Dakota is currently having the rear brakes replaced because the e-brake seized up this winter and warped the drums.
I'm flabbergasted, never having heard of such a thing before. It certainly never felt like the the rear brakes were dragging, and the symptoms only showed up in the last week or so when they started to thump as I was coming to a stop at a light or stop sign.
Old Mar 14, 2007 | 04:58 PM
batman13's Avatar
batman13
Default RE: Emergency brake Seized, Warped Drum Brakes
do you use the e-brake?
if it is a little engaged it would heat up the drum and if its cold out it could warp them
Old Mar 14, 2007 | 05:22 PM
00 Dakota's Avatar
00 Dakota
I never use the e-brake at all.
Old Mar 14, 2007 | 06:13 PM
Casper50's Avatar
Casper50
If you drive in the snow you probably had someice and slush build up on the e-brake cable just enough to have it engaged but not so much that you felt it. When you get the truck back spray down your e-brake cable with some lithium grease to repel the water so that it doesn't allow the ice to build up.It's a pretty common thing for it to happen here in Colorado. If you don't live in a cold winter climate then just disregard this post!
Old Mar 14, 2007 | 06:14 PM
batman13's Avatar
batman13
hmmm.... thats odd
Old Mar 14, 2007 | 06:29 PM
00 Dakota's Avatar
00 Dakota
Thanks Casper, that must've been what happened.
For the record, I most certainly do live in a cold climate, i.e. Saskatchewan.
The mechanic told me they would use a teflon spray to prevent this from repeating. Is this a suitable substitute for lithium grease?
Old Mar 14, 2007 | 06:40 PM
Casper50's Avatar
Casper50
Yeah, definitely. As long as it repels water and sticks to metal fairly wellit will be suitable for the job. Teflon will work because it pretty much actslike a wax. The water will just bead on the cableand then blow off as you drive instead of freezing to it.
Old Mar 14, 2007 | 06:43 PM
00 Dakota's Avatar
00 Dakota
Ah, good to know. I don't want to repeat a $400 brake job every spring.
Thanks Casper for explaining this to me.
Old Mar 14, 2007 | 06:53 PM
Casper50's Avatar
Casper50
Anytime, that's what these forums are for.
Old Mar 15, 2007 | 01:34 AM
batman13's Avatar
batman13
I forgot the cable runs along the side iof the frame and is exposed at parts,
I use it all the time so the ice dosen't last long
