CEL Vacuum Leak problem
Old Mar 16, 2007 | 09:31 AM
Ptrbilt's Avatar
Ptrbilt
Default CEL Vacuum Leak problem
I'm having a problem with the check engine light on my truck coming on repeatedly. I got the P0442 (M) Evap Leak Monitor Meduim Leak Detected A small leak has been detected in the evaportive sysem.
I assumed the likely culprit was the gas cap. Well I replaced it and the cleared the code. Now the light still comes on every once in a while. Usually when the tank gets to about 1/2 full.
Anybody have any ideas what eles could be leaking besides the gas cap? Is there any way to easily elimante this code from the system?
The truck is a 2002 4X4 QC 5.9L
Thanks,
Peter B
Old Mar 16, 2007 | 10:11 AM
imnothot02's Avatar
imnothot02
Default RE: CEL Vacuum Leak problem
you always shut it off when you fill it correct, could be a line from the gas tank that has a minor crack in it...check these two things first...
Old Mar 16, 2007 | 06:41 PM
Ptrbilt's Avatar
Ptrbilt
Yep, always shut off when filling. Reset the computer today and the filled the tank. We'll see how long it takes to come on a again.
Peter
Old Mar 16, 2007 | 08:09 PM
Chris's Avatar
Chris
Check the rubber lines running to and from the charcoal box. It will be under the bed, close to where the gas filler tube is. It is a little black box with lines running in and out of it.
Old Mar 16, 2007 | 10:59 PM
imnothot02's Avatar
imnothot02
^^ thank you i couldnt rember what the thing was called
Old Mar 17, 2007 | 01:43 AM
Silver01SltQuad3.9V6's Avatar
ORIGINAL: virused
+1. Odds are that one of the hoses has a hair-line crack in it. Also, check for proper connection/seal at the hose nippleconnection(s) at the Box.
Good Luck.
