Brake Rotors
Old Mar 18, 2007 | 01:35 PM
jpuder's Avatar
jpuder
Default Brake Rotors
2001 SLT Quad Cab 4.7L
Hey, how do you get the front rotors off? Do you have to remove that large (size?) center nut?
Thanks!
Old Mar 18, 2007 | 02:01 PM
imnothot02's Avatar
imnothot02
Default RE: Brake Rotors
no on mine i just used a 3lb dead blow rubber hammer, most of the time rotors have 3 small screws that you put in to get them off however the dakota doesnt...
Old Mar 18, 2007 | 02:10 PM
jpuder's Avatar
jpuder
Ok thanks. I need a bigger hammer!! I worked on them for over an hour yesterday before throwing in the towel.
Old Mar 18, 2007 | 02:13 PM
imnothot02's Avatar
imnothot02
do this in saya clockwise fashion they are just froze up with rust, also you can use even a bigger hammer than that, but it gets awkward depends how big ya are! [8D]
Old Mar 18, 2007 | 02:18 PM
jonnymagnum's Avatar
jonnymagnum
make sure the calipers are off first
Old Mar 18, 2007 | 02:27 PM
f0x672's Avatar
f0x672
make sure you use never seize when you reinstall the caliper bolts... you dont need those damn things snapping on you
Old Mar 18, 2007 | 09:58 PM
imnothot02's Avatar
imnothot02
make sure to grease the brake pins
