intermittent AC compressor
Old Mar 29, 2007 | 01:40 AM
imnothot02's Avatar
imnothot02
Default RE: intermittent AC compressor
and it isnt cooling the truck down..?
Old Mar 29, 2007 | 03:13 AM
nim81's Avatar
nim81
nope blows regular "not cold at all" air
Old Mar 29, 2007 | 04:18 AM
Rakaric's Avatar
Rakaric
it needs a recharge of freon, lolz. I'm tellin ya..My house AC is like that right now...and all ACs work the same.
Old Mar 29, 2007 | 01:54 PM
Erich_121's Avatar
Erich_121
If your low on refrigerante it will cycle like that. If your full then it could be a faulty compressor clutch.
Old Mar 29, 2007 | 08:46 PM
white97's Avatar
white97
First I should apologize to imnothot02 for my "like your brain "comment. In my defense though I had a little left over rage from work and it was anon-answer. My AC is low on refrigerant, I get that part. Why (or how)does that make my compressor cycle on and off? That was the question. I am assuming that there is a pressure sensor or switch that is controlling the clutch engagement to keep thecompressor from burning out when the system is low or empty. Is this correct?
Old Mar 29, 2007 | 10:51 PM
imnothot02's Avatar
imnothot02
Ah ur fine I'm generally a jerk on here ne way i deserve it!
Here as a A+ article that will help you in understanding the a/c system! http://www.familycar.com/Classroom/ac1.htm
