e3 plugs
Old Mar 27, 2007 | 09:17 AM
wink2873's Avatar
wink2873
Default e3 plugs
has anyone ever tried e3 spark plugs? Im about to take out my bosch platinums. They're causing my truck to run like crap. A guy on another dakota forum is a mechanic with his own shop and he actually dyno'd his truck after putting in e3's and got real hp/tq gains at the wheels over the NGK's he had in before.
So i was wondering if anyone had tried them??? also should I think im gonna go one range colder than the stock range since my truck has always had some knocking problems, and at one point i had in autolite 3923's and that seemed to help the knock (one range colder than stock) anyone tried them?
Old Mar 27, 2007 | 11:12 AM
HankL's Avatar
HankL
Default RE: e3 plugs
the e3 sparkplugs webpage
writeup says 'all the right things'
engineering wise
about reducing cylinder to cylinder variation,
but it is still hard to for me to believe.
The gain from sparkplugs is down in the 10% or less range
and to detect these slight gains you need to do a
'two truck test' (see below)
rather than rear wheel dyno runs
which naturally 'jump around' at least 6-10%
and make it nearly impossible to see if less than 10% gains
are real.
If you do get the e3 sparkplugs
install them first in a friend's truck
and follow him around doing some testing for acceleration and fuel economy,
then put the e3 sparkplugs in your truck.
If both trucks improve with the e3 sparkplugs
and (importantly) get worse without them
...then they really work.
Got a buddy with a Dodge Ram with the overhead trip computer?
(His truck does not have to be exactly the same as yours, but the closer the
better)
Since you are making a modification with hopes of getting better MPG
why not do a "before & after" test?
Do a 'before test' with both trucks
* you and your buddy fill up at the same gas station and put the same air
pressure in all tires
* Pick a highway without too much traffic and hopefully where the wind is a
head wind or tailwind (side winds mess things up)
* Your Ram and your buddy's Ram follow one another staying at least 6 vehicle
lengths apart
* talk to one another with cell phones or walkie talkies
* drive at the same speed
* reset the overhead computers at the same time
* drive at least long enough to burn up 2.5 gallons
* exit highway, turn around, and continue the test in opposite direction
(this is to partially cancel out wind direction)
* write down average MPG on overhead computers at end of run
and compare this to the gas pump numbers and odometer mileages.
After doing your modification
redo the test the same way as above,
hopefully at a time of day where the temperature is about the same as the
'before' test and the wind speed & direction is not a problem - which you
can check here:
http://tribunewx.wunderground.com/US...WindSpeed.html
Note that in the above weblink you can type in your zip code and get exact
wind, temperature and other weather data.
The value of your buddy's pickup being along on is that on this 'after' test
if his MPG is greatly different you should suspect something has gone wrong
like strong cross winds, a change in temperature, tire air pressure, etc.
If you want to test two trucks against one another that are already modified
like comparing 3.55 differential gears to 4.56 gears
or an underdrive pulley, syn versus dino oil, tire air pressure, thermostat,
SuperChips, etc......
you can modify this test slightly for even better accuracy.
Swap two tires from one truck to the other.
Now both trucks have the same 'average' tires.
Weigh the trucks and add weight to the lighter truck to make them even.
If you really want 'gold standard' accuracy that you can trust
(or if you are measuring a small effect like a thermostat)
then swap the mod over to your buddy's truck
and do the tests another time with your truck as the 'control'.
If you are presently thinking:
"Wow, who would be that careful for a lousy MPG test?"
then just think about a dragstrip
which will have:
carefully measured distances,
highly accurate timing trigger by light beams,
know its altitude,
have a weather station,
and have a computer program to 'adjust' results for weather conditions.
All this type of MPG test is doing is applying the same standards to MPG
that is expected when someone brags about their vehicle's ET or MPH in the
quartermile.
By doing a test this way you are doing a simplified version of a
SAE/TMC Type IV fuel economy test RP 1109.
Here the SAE stands for Society of Automotive Engineers and
TMC stands for Truck Maintenance Council which is a group
of professional 18 wheel truckers who have banded together to share
information. RP stands for recommended procedure.
Credit for inventing a 'reliable' MPG test like this goes to many, but
especially Claude Travis, known to his peers at TMC as "Mr. MPG,"
who has spent 37 years managing the operation, maintenance and testing
of heavy-duty, on-highway vehicles. Highly regarded for his exhaustive
research in the field of heavy-vehicle fuel-economy, he is principal of
Claude Travis and Associates, Fleet Consultants, Grand Rapids, Mich.
In the actual SAE/TMC type IV test they also take the temperature of the
fuel both before and after, because a gallon of fuel coming out of an
underground tank at 57 degrees F will expand/contract several percent
as it approaches that day's air temperature.
If you are interested in learning more about this
there are also SAE/TMC tests I, II and III
and no doubt someday an even better test V will be invented.
