wet floor board
Old May 11, 2007 | 02:21 AM
scootie's Avatar
scootie
Default wet floor board
1998 Dakota, problems with wet floor board on passenger side. cannot find the drain hose for air conditioner. Any ideas where to look? Or any other reason it would be so wet even when there is no wet weather?
Old May 11, 2007 | 02:27 AM
User's Avatar
User
Default RE: wet floor board
heater core... good luck fixing it.. its a bitch.
Old May 11, 2007 | 02:30 AM
jonnymagnum's Avatar
jonnymagnum
ORIGINAL: User2006
+1
unless your already using your a/c, then it could be the a/c drain hole is plugged.
do you smell coolant at all?
Old May 11, 2007 | 12:41 PM
imnothot02's Avatar
imnothot02
mnine was the crappy ac drain design, the drain on mine is just a stub about a quarter inch out of the firewall and when driving down the highway the water would blow rite back into the cab, i used a piece of hose and a elbo to fix mine...no water since
Old May 12, 2007 | 09:25 PM
scootie's Avatar
scootie
Thanks for the replies! I smell no coolant so I don't think it is the heater core. I am having a hard time finding the a/c drain hose. Please let me know if you can tell me where on the firewall it is. Thanks again!
Old May 13, 2007 | 12:56 AM
imnothot02's Avatar
imnothot02
very hard to see... right behind the block on mine about half way down the firewall
Old May 17, 2007 | 10:15 PM
F1ashman's Avatar
F1ashman
FWIW had a leak in my extended cab both front and rear floorboards of the driver's side and turned out to be a leak from my rear window seal. Water ran down the back of the cab and was not noticeable because of the trim and seats etc.. Have someone hose the rear window areadown while you are inside watching and maybe some RTV will be a quick fix. Good luck
Old May 17, 2007 | 11:41 PM
JBs DAK's Avatar
JBs DAK
You need to locate the drain-hole 1st. (If you have been running your A/C, otherwise, it's gonna be a heater-core or a window leak.
You can use a trans cooler hose about 10 inches long and let it hang down the fire wall to help draining. Use nothing stonger than a big pipe cleaner to clean the drain hole. You can poke a hole in your condensor real easy!
Old Aug 5, 2007 | 04:50 PM
szf's Avatar
szf
a/c drain is very low on the fire wall. it's not easy to access. if the water on the floor doesn't smell like antifreeze it's probably not the heater core. use silicon seal on all gaskets going thu the fire wall.
Old Aug 5, 2007 | 05:02 PM
imnothot02's Avatar
imnothot02
^ thanks for the input, kinda a old thread...
