Electric fan conversion
Old Oct 6, 2008 | 06:03 PM
00DakR/T's Avatar
00DakR/T
Default Electric fan conversion
So my fan clutch is shot (as I found out one of our 100 degree days awhile back...) and I want to do away with it and run electric only. I had thought about getting a Viper fan conversion from socaldakota.com, but since the site took a dump, I don't really know what to go with. Anybody done this on here? 360 or not?
Old Oct 6, 2008 | 06:55 PM
batman13's Avatar
batman13
im surprised the R/Ts didnt come with electric fans....
most performace shops sell e-fan kits
Old Oct 6, 2008 | 07:00 PM
big.bryant's Avatar
big.bryant
don't the dakotas come with both? electric and clutch? what if you took your clutch fan off and just had your electric? or would that not work?
Old Oct 6, 2008 | 08:58 PM
MadisonDakota's Avatar
MadisonDakota
I don't think so, but if it did, it wouldn't move enough air.
Old Oct 6, 2008 | 09:48 PM
00DakR/T's Avatar
00DakR/T
R/T's and most other V8 Daks and Durangos have both. The problem with just using one is this.....the stock electric fan only comes on when either the A/C is on or the coolant temp reaches 230. Which is way too hot for anything with a S/C. I was thinking I could install a pusher fan in front of the A/C condenser and leave the stock electric fan, or get a 2 speed fan to mount on the engine side but I don't know which is better or easier to do.
Old Oct 6, 2008 | 10:06 PM
MadisonDakota
What ever you do, tell me, I plan on doing the same mod.
Old Oct 6, 2008 | 10:57 PM
rtdakota2001's Avatar
rtdakota2001
mine came with one....
Old Oct 6, 2008 | 11:06 PM
f0x672's Avatar
f0x672
well... aren't you o so friggin special..
haha, jk
Old Oct 7, 2008 | 01:48 AM
varsis's Avatar
varsis
Rewire the electric fan to run on a switch or make it run all the time. No harm in that.
Old Oct 7, 2008 | 05:18 AM
JBs DAK's Avatar
JBs DAK
Get a Mark-8 fan. It moves 5800 CFM.
You use it as a puller. As a pusher you
will lose 30% right from the get-go.
It's a two-speed fan. A/C on & off.
I think you can still get them for under
a buck-fifty. (Or, hit the bone-yards and
find one for ten-twenty bucks).
If your truck has a pusher already, just
get rid of the clutch-fan & Wire it in for
low speed only,.. It moves 3250 CFM on
low. Do it,.. It will free up some HP for
ya and, better MPH too.
