p1756 question
Old Jul 21, 2009 | 10:00 AM
mwp71467's Avatar
mwp71467
Default p1756 question
It's a '97 Dakota v6 w/ a 44re tranny. Not shifting out of 2nd gear when engine reaches normal operating temp. I've replaced the solenoid and transducer with mopar parts,changed the fluid and filter twice. Noticed quite a bit of metal in pan first fluid change and 15k miles later changed fluid again and more metal in pan. OBD2 scanner throws p1756 but the description following the code reads "manufacuer ctrl. transmission" ( and thats how it's spelled in the scanner). I have not seen this defintion of a p1756 code anywhere. I understand this code relating to govenor pressure but typically thats the definition following the code. Anyone heard of this definition or is it time for a new tranny?
Old Jul 21, 2009 | 12:48 PM
Billiam's Avatar
Billiam
P1756 (M) Governor Pressure Not Equal To Target @ 15-20 PSI Governor sensor input not between 10 and 25 psi when requested to be 0 psi. (4-speed auto. Trans. Only)
I'd change that there sensor... see what happens.
Old Jul 21, 2009 | 07:37 PM
mwp71467's Avatar
mwp71467
I'll give it another try. Perhaps the one I installed was bad or something shorted it out. Thanks for the reply B
Old Jul 22, 2009 | 11:36 AM
Billiam's Avatar
Billiam
No prob. May check the wire and such, make sure there is no bare spots that are grounding out.
Old Jul 23, 2009 | 08:44 AM
mwp71467's Avatar
mwp71467
Will do. I'm working on the dakota today and I will let you know my findings. Thamks again B
