HELP...01 Dakota, 4.7, auto, - Coolant Leak
Old 07-29-2015, 04:08 PM
ibcnul8r's Avatar
ibcnul8r
ibcnul8r is offline
Default HELP...01 Dakota, 4.7, auto, - Coolant Leak
On my Dakota, I'm seeing antifreeze on the front bumper, driver side. I've looked all over under the hood and can find no evidence of a leak.
It seems to be up high (above the bumper?), but there is also evidence that it's blowing underneath because I can see it on the cross member beam.
Anyone else have this problem? Anybody have any idea what/where the leak could come from.
No water in oil
Thanks for the help. Much appreciated.
Old 07-29-2015, 05:18 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Check your coolant level in the tank? Is it very full? How are the hoses connecting the tank to the radiator cap?
Check the short radiator hose/cap assembly for cracks. It may be leaking under pressure. Could be the cap too.
Old 07-29-2015, 05:23 PM
Robertwav1's Avatar
Robertwav1
Robertwav1 is offline
Like Dan had said, definitely check the cap as they can bypass into the overflow under pressure while your driving. I had one bad once in another vehicle and found out the antifreeze was coming out of the overflow through the cap which had a deteriorated seal.
Old 07-30-2015, 02:35 PM
ibcnul8r's Avatar
ibcnul8r
ibcnul8r is offline
Thanks for the replies folks. Much appreciated. Will be getting a pressure test done in a couple days.
Thanks again.
Quick Reply: HELP...01 Dakota, 4.7, auto, - Coolant Leak
