2nd Gen Durango 2004 - 2009
Seat Belt Alarm on 04 Durango
Old Jul 3, 2013 | 07:08 AM
j4grave's Avatar
j4grave
yep. Noticed that when I replied. Just got a used rango this spring. Thought I'd chime in in case another new member like me was looking for help. Thanx all the same,
Old Aug 9, 2022 | 04:58 PM
Kildd's Avatar
Kildd
Default It worked
Originally Posted by chrisandclauida2
there is a way to shut off the bell. i will post two different plays on the proceedure.
1.buckle the belt without the key in
2.insert key turn it on but dont start engine
3.wait till the seat belt light turns off
4.unbuckle and buckle the belt 3 times.
5.leave the belt buckled
6.turn key off and you should hear a chime if not start over and add a buckle unbckel cycle each time you try.
a different method some say work
1.turn on key without starting the engine and with belt unbuckled.
2.buckle and unbuckle till you hear a chime.
this allows the chime to ding at start up then the light comes on but no chime.
there is a duscussion of this on the dodgrboy.com site under 2004 durango.
I tried the 1st method multiple times to no avail.
The second method worked on my 05 dodge durango. Thanks so much!
