2nd Gen Durango 2004 - 2009
Airbag Light
Old Jun 8, 2007 | 01:50 AM
motox851's Avatar
motox851
Default Airbag Light
My wife said today that the airbag light started blinking on and off when she was driving this morning. I drove it around for awhile and didn't have any problems. Do you guys know what might be the problem? Also, is there a way to turn the passenger air bag off? My Jeep TJ I used to own had a key switch in front of the shifter but I can't find anything on this Durango. It's an 04, if that matters.
thanks
Old Jun 8, 2007 | 10:22 PM
wolfee's Avatar
wolfee
Default RE: Airbag Light
I had this same problem... If you can call it that.
She probibly had something in the passanger seat, say a lunch box, or a heavy jacket, something around 1.5 pounds. The sensor was picking it up and arming and disarming the air bag every time she hit a bump.
You can test this by placing your hand in the middle of the seat, as you drive down the road. the light should come on if you lightly rest your hand on it and off if you apply more pressure, or remove it.
As far as turning it off and on... The passsanger seat has a pressure sensor in it that will arm/disarm it. no manual setting.
Old Jun 10, 2007 | 01:13 AM
motox851's Avatar
motox851
thanks for the info. that would explain why it never comes on when I'm driving it and she's with me. She puts her purse in the passenger seat when she's by herself, which explains why the light comes on and off.
Old Sep 23, 2007 | 10:54 PM
poppadz's Avatar
poppadz
Keep an eye on that light I am having the same problem. I notice it every once in a while and I have even took it in to the dealership and said there was no problem.The light goes on and off even when there is nothing in the seat. My opinion is the senser in the seat .
Old Sep 27, 2007 | 02:16 PM
callie522's Avatar
callie522
I have a 2006 and my airbag light came on the same time as my cruise and my horn quit working.
Old Sep 29, 2007 | 10:15 PM
traintrackker's Avatar
traintrackker
My Durango has had the same issue and has been to the dealer on several occaisions. So far, no fix. It's very sporadic, but still smacks of quality control issues with the electrics. Good luck.
traintrackker
Old Oct 14, 2007 | 12:09 AM
nowick's Avatar
nowick
i have a 06 dakota and the damn light keeps comin on they have atempted to fix it 8 times no good cant fix it I think it a lemon law deal now how can they tell if the airbag will or will not work just in case i need it. safety issue if you ask me i smell new truck!
