2nd Gen Durango 2004 - 2009
Overheating!!!
Old Aug 18, 2007 | 10:01 AM
brgshw's Avatar
brgshw
Default Overheating!!!
My Hemi has 65,000 miles on it. I have been overheating, even more so with AC on. I've had the system flushed, new fan clutch, and thermostat. Still running WAY too hot. Any suggestions, please!!!! Thank you!
Old Aug 19, 2007 | 06:00 PM
n8ech's Avatar
n8ech
Default RE: Overheating!!!
brgshw:
What condition does it overheat under?? Idling in the driveway, running down the highway.
If this is the first flush you have had done since new, it might be a clogged radiator. The real bad news would be a bad head gasket leaking hot combustion gases into the coolant. If this were to be the case though, as long as your rig has the 7/70 powertrain coverage in effect it would only cost you $100.
Don
