2nd Gen Durango 2004 - 2009
see this computer
Old Nov 3, 2007 | 10:46 AM
durango^hemi's Avatar
durango^hemi
Default see this computer
B&G Performance PCM Flash, 3.7L/4.7L/5.7L Hemi Truck/Durango/Jeep Flash (03-07 NGC)
SKU: BGTRUCK
In business since 1974, B&G Chrysler Specialists, Inc. are an independent automotive specialty service and repair facility specializing in 1996 and newer PCM (Computer) performance upgrades. B&G's Dodge, Chrysler and Jeep PCM flashes have been on the market for a long time and here at HHP almost every major build we do leaves here with a B&G flashed PCM. These reflashed PCM's allow your car to better take advantage of the modifications you have done by opening up and widening your vehicle computer's operating parameters and allow for even improved performance on a stock vehicle.
This B&G PCM upgrade is designed for stock vehicles or vehicle with some modifications (mild cam, cold air, headers). For highly modified vehicles or special calibrations, contact HHP before purchasing. Current modifications include:
03 Hemi: Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, modified torque management
04 Hemi: Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, modified torque management
05 Hemi: Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, modified torque management
06 Hemi: Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, modified torque management, MDS option disabled
07 Hemi: Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, modified torque management, MDS option disabled
03-07 3.7L/4.7L: Premium fuel & (MBT) timing curves, 750 idle, 140 mph, modified torque management
Required Information: To tune your engine we need additional information regarding your vehicle in order to send you the appropriate tune. We need your VIN, located on your drivers-side door or on your dash plate, and the "Authorized Software P/N" (part number) located on a sticker on your stock PCM. We need to know which of the 27 stock tunes your vehicle needs. **All Above calibrations have engine stall torque management modified.
Note 1: With this purchase, you must remove your factory PCM and ship it to HHP. Your PCM will be flashed and sent expedited back to you within approximately 4 to 5 business days.
Note 2: B&G PCM Modifications are for OFF-ROAD use only, and sold "as is" unless otherwise noted. You should check with your vehicle manufacture for any warranty concerns before installing any PCM Upgrade. B&G Chrysler Specialists, Inc. assumes no responsibility for any warranty concerns due to the installation of our PCM Upgrade, which is intended for OFF- ROAD Use Only. Additionally PCM upgrades may affect the emissions characteristics of the vehicle. If you install PCM Upgrade and your vehicle consequently fails state or local I/M emissions test, including any test required to maintain or renew your vehicles registration, or if your vehicle is subject to a emissions recall, B&G Chrysler Specialists, Inc. is not required to repair your vehicle, and you may be required to remove the PCM Upgrade at your own expense in order to obtain repairs necessary to pass the I/M test or to perform the recall.
Note 3: HHP also carries spare PCM's. If you don't want to remove your factory PCM for flashing, we will flash a second PCM and you can keep your factory PCM stock. This will allow you to return your car to stock at any time. If you take your car in for service you run the risk of your dealership overwriting your B&G flash. Check out the link below to the spare PCM.
http://estore.websitepros.com/802805/Detail.bok?no=1205
Old Nov 5, 2007 | 01:27 PM
sca's Avatar
sca
Default RE: see this computer
That is exactly what I have done to my Durango! Also have a spare PCM...
Old Nov 6, 2007 | 07:59 PM
durango^hemi
can you give me this site for a spare PCM?
Old Nov 6, 2007 | 09:19 PM
sca's Avatar
sca
I let you know the site tomorrow!
Old Nov 7, 2007 | 08:18 AM
sca's Avatar
sca
https://www.trademotion.com/memberse...iteid%3D214346
I got my PCM here, talk to Alan, it is around 400$.
Old Nov 7, 2007 | 02:27 PM
durango^hemi
mR:sca
can you add me i wont talk for my car happy_88_face@hotmail.com
thanks
Old Nov 8, 2007 | 04:29 PM
sca's Avatar
sca
I have no idea what you are talking about?! Where do you want me to add you?
Old Nov 11, 2007 | 05:03 PM
durango^hemi
in msn messenger
Old Nov 12, 2007 | 09:40 AM
sca's Avatar
sca
I'm not actively using msn messenger, all I have is a hotmail account.
