2nd Gen Durango 2004 - 2009
Fuse Layout
Old Nov 13, 2007 | 02:30 PM
nyscuba's Avatar
nyscuba
Default Fuse Layout
Does anyone have a fuse layout for the 2004 durango My user manual shows where it is but does not show what they go to
Thanks
Old Nov 13, 2007 | 03:40 PM
SinCity R/T's Avatar
SinCity R/T
Default RE: Fuse Layout
Check the inside surface of the fuse box lids, 98-03 models had the layout information molded into the plastic. I'm not sure if 04+'s are the same, but it would be silly of Dodge to not put the info there anymore...
Old Nov 13, 2007 | 04:07 PM
nyscuba's Avatar
nyscuba
there is no info on the inside cover of the fuse box in the passenger compartment
Old Nov 13, 2007 | 04:46 PM
SinCity R/T
ORIGINAL: nyscuba
Silly Dodge... Did a little bit of digging, looks like they screwed that up on the 2004, but added the fuse list to the 2005+ manuals...
http://www.2ndgendurango.com/extras/2004_Fuses.pdf
Old Nov 13, 2007 | 07:01 PM
nyscuba's Avatar
nyscuba
thanks i will try this
Old Feb 6, 2008 | 07:10 PM
wizardny1's Avatar
wizardny1
The diagram from the above link does not match the fuses in my 04 Durango. anyone have any other info?
Old Feb 7, 2008 | 02:00 AM
asosnov's Avatar
asosnov
In my 04D, the fuse block is under a cover near the park brake pedal, and there is a diagram on the inside. Unfortunately, the diagram shows only the fuse number, not the chain it protects.
Alex
