2nd Gen Durango 2004 - 2009
How Much Trailer?
Old Jan 12, 2008 | 08:51 AM
Carver's Avatar
Carver
Default How Much Trailer?
Guys I am looking into buying an enclosed trailer to haul my 2 motorcycles which by themselves are about 1400 pounds, not including associated gear or luggage etc. I would like to get as big a trailer as I can pull with my 05 Durango which has the hemi. I am looking at dual axle 7x16 enclosed trailer.
What are the opinions of this trucks abilities. My destination is normally south from NY through the hills of PA and the Carolinas'. I have pulled a 20' dual axle landscape trailer from NY to Florida and back loaded with furniture and stuff, and the truck easily handled it without a problem...
Anyway just looking for some opinions..
Forgot to mention I do have the factory towing package.. I realize what the manual says for max wieght but I have to think there is a difference between a 5000lb landscape trailer and a 5000lb enclosed trailer as far wind resistance etc..
Thanks
Carver
Old Jan 12, 2008 | 09:50 AM
Duranged408's Avatar
Duranged408
Default RE: How Much Trailer?
looking around it says a 8,950-pound tow rating. Ive seen it donewith a race trailerand the hemi handled it fine, trip to FL from NY and back. Some guys should be able to chime in soon and give you a better weight limit.
Old Jan 18, 2008 | 12:52 PM
00zx6r's Avatar
00zx6r
I am pullingthe enclosed trailer Haulmark 8.5x18 full setupwith tool box,cabinets, genset, 25gals air compressor 2 ATVs and 2 dirts bike, all gears and so on... 6% grade mountain seems to be ok. The only thing is the backof the D is pushed down a bit. The rear air bag is on the way. Also, Ihave 04 Hemi with 2 speed transfer case all stock. Compared to my 98 Ford Expy EB this D isout performed the Expy EB.
Old Jan 18, 2008 | 06:11 PM
Carver's Avatar
Carver
00zx6r
Thanks for the help. are you using a load stablizing hitch?
I take it the air bag(s) is to help keep the truck level?
It's funny I traded in a v10 ford exp. for the Durango, and really thought it handled the hills much better then the v10 did.
Thanks again.
Old Jan 18, 2008 | 11:52 PM
markgpz's Avatar
markgpz
One BIG problem with the so called "tow package" is that it lacks the addition of the 3.92 rear gear. This gear is a "seperate" order ($60) on the invoice that is not included in the tow package. The stock 3.55 gear that comes with the tow package is a big mistake for those that want to tow a larger load. Most (99%) of the D's with the tow package have the stock 3.55 gear. If you look at the sticker in the glove box it lists the rear gear ratio that the D has. I bought my 04 Hemi D Limited used with the 3.92 and I had a big problem trying to find a used one with the 3.92 gear.
I pull two different trailers. My 5,000 lb open race car trailer that siloetes the roof line of the D is an easy pull at 75 mph and the D stays in coverter lockup even in large highway inclines. My other trailer a 3,300 lb enclosed V-nose trailer that is 18" over the top of the D roof line is a much harder pull than the 5,000 lb trailer because it's basically a big sail in the wind. The D likes to run in the tow/haul mode with this enclosed trailer as it won't stay in converter lock up .
Old Jan 23, 2008 | 12:09 PM
00zx6r's Avatar
00zx6r
Carver
I dont use load stabilizer.
markgpz
You are correct the D Hemi with tow package most standard of 3.55 gear. Since I bought I used so I have no choice but if it were brand I definitely select 3.92 gear for towing.
