2nd Gen Durango 2004 - 2009
keys
Old Jan 30, 2008 | 05:34 PM
lehneer's Avatar
lehneer
Default keys
both of my key fobs don't work. i've changed the batteries. still ulnock-lock-panic= nothing. i have to unlock the doors manually. what do i do next. it'll cost 60 bucks just to have the dealer look at it. hope someone has some advice thanks
Old Jan 30, 2008 | 07:02 PM
onephatcracka's Avatar
onephatcracka
Default RE: keys
Iknow at some autozones they have a display for energizer batteries that has an RF detector. Thats the frequency that your key puts out. If new batteries were installed and it doesn't detect it then you will end up needing new keys.
Old Jan 30, 2008 | 07:12 PM
n8ech's Avatar
n8ech
Default RE: keys
There is a fuse (don't know which one) that you can pull to reset the computer that controls the locks. If this does not work, you willl probably have to spend the $60.
Don
Old Jan 31, 2008 | 11:39 AM
Parts/Service's Avatar
Parts/Service
Default RE: keys
Check to see if the spring clip that holds the battery in is still soldered to the circiut boad. These clips have a tendency to break off the pc board........
Old Feb 1, 2008 | 08:55 AM
asosnov's Avatar
asosnov
Default RE: keys
If both keys fail at a time, this does not look like a battery issue.
Old Feb 9, 2008 | 08:57 PM
Mechster1's Avatar
Mechster1
Default RE: keys
I was a victim of the bad solder joint on the fob's battery hold down clip. Actually it was my wife's key that went bad. She swapped her key with mine and didn't tell me. I drove the car all day with the bad key and it was a real pain. Every time I unlocked the car manually with the key the car alarm horn started beeping, attracting all kinds of unwanted attention.
Anyway, it is an easy fix. Just pull out the printed circuit board and resolder the joint.
Mechster1
