2nd Gen Durango 2004 - 2009
Interior/Courtesy Lights
Old Aug 3, 2008 | 01:15 AM
quikone's Avatar
quikone
Default Interior/Courtesy Lights
I just noticed that my wifes Durango interior/courtesy lights ar no longer functioning. The lights will not activate by opening any door, or by rolling the dimmer all the way up. They will however still function if you depress them directly. I've seen some similar posts, but have yet been able to find a fix/resolution to the problem. Any help is appreciated. Thanks.
Old Aug 3, 2008 | 02:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Interior/Courtesy Lights
Did you get a recall notice for the cluster? If the recall has not been do, have it done. If it has been done then go to the dealer and say since the recall was done the dome lites don't work. You may need a new cluster.
