2nd Gen Durango 2004 - 2009
05 ST Fog Lights
Old Sep 21, 2008 | 01:11 AM
bribo's Avatar
bribo
Default 05 ST Fog Lights
My ST did not come with fog lights. I have the holes, but they have the insert, slits, or fins, I can't get them out. Can I drill or cut these out and add the factory size fog lights to this front? If so, how will I secure them into the bumber? I was just thinking about buying a bumper from the JY from a SLT model and adding it. Any idea on costs, whats more expensive?
Thanks!
Old Sep 27, 2008 | 10:16 PM
hydrashocker's Avatar
hydrashocker
They should just pop out!.......Hmmmm....
You can get the hardware from the dealer to install them.
Old Sep 28, 2008 | 09:03 PM
jaabickford's Avatar
jaabickford
little bit of a process for doing what your thinking...your best bet is gonna be going aftermarket for a set of fogs...if you looking at doing it stock you in for spending a few $$$, headlight/foglight switch, wiring, relays, lamp assembly's, and all of this is going to be dealer parts so your gonna spend a few bucks, I work at a dealer and get asked this all the time, very quickly adds up to anywhere from $500 to $1000. those covers in your bumper should pop right out and all the mounting points should be there, if your lucky..lol. the aftermarket fogs wont look as clean as stock, but it'll be a he*l of a lot cheaper. good luck.
