2nd Gen Durango 2004 - 2009
04 Durango Problem
Old May 2, 2009 | 08:04 PM
daveyboy43's Avatar
daveyboy43
Default 04 Durango Problem
Have an 04 Durango with 4.7.liter engine. Vehicle just started making what I would describe as almost like a metal on metal rubbing or light grinding noise but not very severe and it seems to be coming from what I think is the a/c condenser or compressor located to the left of the alternator. It has a pulley on it and was just wondering whatever this part is does the pulley for it have a bearing in it? I'm not sure what that part is but that's where the noise is coming from. just wondering if anyone has any ideas? Any suggestions on what I could do to maybe pinpoint the problem? As always thanks for any and all help.
Old May 3, 2009 | 03:53 PM
hydrashocker's Avatar
hydrashocker
It is the A/C clutch.
If you look into the bearing most places like Auto Zone have it. Could also the clutch pads worn out and needing replacement.
Old May 3, 2009 | 09:35 PM
daveyboy43's Avatar
daveyboy43
Forgot to mention that the noise is more noticeable when you accelerate and less when you're off the gas. Still think it's the A/C clutch bearing or could it be the idler pulley?
