2nd Gen Durango 2004 - 2009
Mirrors, door handles and door panel removal?
Old Jun 9, 2009 | 11:18 PM
rbenkemeadow's Avatar
rbenkemeadow
Good comebacks. Another DUMB F'N COMMENT
Pics posted and tomorrow I will post the finished picture.
Old Aug 20, 2011 | 10:13 PM
abldo96's Avatar
abldo96
Great write up and pics, looking to do mine this week. Thanks for the tips!
Just read your write up on painting the mirrors and handles, great stuff! Exactly what I have been wanting to do.
Did you do anything special to the rough black plastic besides using bulldog adhesive to make the paint stay? Also did it come out smooth or is it still a little rough after painting?
Wondering about sanding etc, if you can fill in the blanks I would appreciate it!
Old Aug 20, 2011 | 11:50 PM
rbenkemeadow
To answer your pm, you scrub the black plastic with a green scratch pad and clean well. It's been a year now since I parted with the durango for the srt8. I did just paint the wife's mirrors and door trim on the traverse.
Picture of the door trim
Mirrors and door trim
Added different bulbs also
Also I left the bully dog kind of tacky then sprayed the first coat. Be careful of the humidity and outside temps because that can change drying time etc. If its warm out when you spray do not take item into air conditioning when finished because it will start show whit spots from the clear. Yes its smooth as can be but the roughness of the plastic will still be there up close.
Old Aug 21, 2011 | 12:41 PM
abldo96's Avatar
abldo96
Thanks, how about the small plastic piece forward of the mirror on the Durango, how does that pop off?
Thanks again
[qurote=rbenkemeadow;2577141]To answer your pm, you scrub the black plastic with a green scratch pad and clean well. It's been a year now since I parted with the durango for the srt8. I did just paint the wife's mirrors and door trim on the traverse.
Also I left the bully dog kind of tacky then sprayed the first coat. Be careful of the humidity and outside temps because that can change drying time etc. If its warm out when you spray do not take item into air conditioning when finished because it will start show whit spots from the clear. Yes its smooth as can be but the roughness of the plastic will still be there up close.[/quote]
Old Aug 22, 2011 | 09:21 AM
rbenkemeadow
Not sure which piece that is. If you can take a pic and post up here. Also you don't have to remove the actual mirror out of the housing to paint the mirrors. It was a pain and very difficult to not snap the little black plastic tabs.
Old Aug 22, 2011 | 01:21 PM
abldo96's Avatar
abldo96
Yes, I will leave the mirrors in place, it looked a little too tricky to pull out anyway.
Talking about the piece of plastic in this photo just forward of the miorror.
Attached Thumbnails Mirrors, door handles and door panel removal?-100_2701.jpg
Old Aug 22, 2011 | 03:19 PM
rbenkemeadow
I can't remember how it came off but I bet it's just clipped on. Looking at the pics, it's after the door opening so I bet it just pops off.
Old Jan 11, 2012 | 11:42 AM
alt-fuel's Avatar
alt-fuel
I do like the paint job on handles and mirrors. One question bully dog adhesive is that a brand name? Can it be purchased at autopart store? What could be used instead?
Old Jan 12, 2012 | 01:13 PM
abldo96's Avatar
abldo96
It's a brand name, Autozone and the others have a Krylon one just as good I have been using, it goes on light gray/white, real nice if you are lightening up your color. I have tried another brand as well, cannot remember the name but it goes on clear and doesn't work worth a darn.
Old Jan 12, 2012 | 02:53 PM
rbenkemeadow
Bullydog is the name of the product and its an adhesion promoter. It's the best stuff you can buy in a can unles you want to spray it out of paint gun. The biggest reason I used this, is any time you paint plastic it flexes. This helps the paint flex too. I never had any cracks on the peice under the bumper at all. The other brand I would use if I had to would be duplicolor.
