2nd Gen Durango 2004 - 2009
Need help wiring electric fans
Old Oct 27, 2009 | 04:10 PM
04durangoslt's Avatar
04durangoslt
Default Need help wiring electric fans
I recently installed a set of efans on my durango using a fan controller attached to a relay to power the fans. Right now I have both hardwired to the battery. Everything works well, but the fans run even when the engine is off while it cools down. I would like to wire the fan controller to a hot that is only on when the ignition is on. I tried to locate a place under the hood that was only on with the ignition, but I could not find a good place. I need some suggestions of where I should hook it up.
Old Oct 27, 2009 | 06:22 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
http://forums.trailvoy.com/showthrea...t=48007&page=3
Here is an article about installation,
FF
