2nd Gen Durango 2004 - 2009
Another tool to buy
Old Mar 6, 2010 | 09:53 AM
Tizzy1's Avatar
Tizzy1
Default Another tool to buy
spark plug removal on an '08 Durango, 4.7L
4.7L
<A xmlns="http://www.w3.org/1999/xhtml">
CAUTION: This engine uses TWO DIFFERENT types of spark plugs. A total of 16 plugs are used. The plugs are mounted in two rows (banks). The upper row (5) is used on the intake valve side of the cylinder head. The lower row (6) is used on the exhaust valve side of the cylinder head. The upper row (5) uses Bosch Nickel Yttrium plugs. The lower row (6) uses Bosch Iridium plugs. DO NOT INTERCHANGE THESE PLUGS.
CAUTION: Do not attempt to clean any of the spark plugs. Replace only.
1.Remove necessary air filter tubing and air intake components at top of engine and at throttle body.2.To remove the upper row of plugs (5), each individual ignition coil (2) must first be removed. See Ignition Coil Removal for procedures. Prior to removing ignition coil, spray compressed air around coil base at cylinder head.3.Prior to removing spark plug, spray compressed air into cylinder head opening. This will help prevent foreign material from entering combustion chamber.
CAUTION: Due to tight clearances between UPPER row of plugs (5) and cylinder head, a conventional deep, thick-wall spark plug socket will not fit. Use a deep, THIN-WALL 5/8” spark plug socket for plug removal and installation.
4.Remove spark plugs and inspect their condition.
Old Mar 6, 2010 | 03:23 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The ones in the back are extremely hard to reach unless you are a 6'6" bsketball player,
FF
