2nd Gen Durango 2004 - 2009
Transfer case problems
Old Apr 12, 2010 | 09:23 PM
nightmareroy's Avatar
nightmareroy
Default Transfer case problems
I got a 2004 Dodge Durango 4X4 it has the NV 244 transfer case on it and a couple of days ago I tried to put my truck in 4Lock and the light on the dash just blinks and it never shifts. So I turn it to 4Lo and it shifts into it no problem then I turn it back to 4Lock and it shifts into no problem. Then I tried to go back to AWD and again the 4Lock light justs blinks on and on and nothing happens and it stay is in 4Lock. The only way to get back into AWD is to quickly turn the switch from 4LO to AWD. Is this my transfer case shift motor going bad or something else?
Old Apr 13, 2010 | 07:57 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Try this link:
https://dodgeforum.com/forum/2nd-gen...o-problem.html
FF
Old Apr 14, 2010 | 09:33 PM
nightmareroy
Problem solve. It was my ABS light causing this problem it was the Rear Wheel Speed Sensor Circuit. Once it was fix the transfer case starting shift like it used to with out a problem.
