2nd Gen Durango 2004 - 2009
Brake controller conections
Old Apr 27, 2010 | 10:47 PM
firemn131's Avatar
firemn131
Default Brake controller conections
Hi All
How do i wire in my Tekonsha brake controller to a 2007 dodge durango,
My Durango did not have a factory tow package. I bought the OEM after market harness from dodge and installed. I ended with a blue wire that terminates under the dash. how do i tie in my controller to this, and is there another plug that i am supposed to add the blue wire into. and then another harness from that to my controller?
here are the part numbers for the installed harness and the controller.
Harness 82209773AC
Controller Tekonsha Voyager TE9030
Thanks for your help.
John
Old Jun 13, 2010 | 10:15 PM
dirtman1972's Avatar
dirtman1972
Default same issue
yea , you have to get a electric brake controller .
the blue wire connects to the blue wire on the controller , the electronic brake controller will also connect to 12v power , ground and i believe the white/ brown wire off the brake switch .
but double check the on the white / brown wire
Old Jun 13, 2010 | 10:36 PM
tmerritt530's Avatar
tmerritt530
It is a beige wire with a tan stripe.
