2nd Gen Durango 2004 - 2009
E3 spark plugs and Leveling my truck
Old Jun 20, 2010 | 01:13 PM
bBlueWolf14's Avatar
bBlueWolf14
Default E3 spark plugs and Leveling my truck
I saw some spark plugs called E3, anybody have any comment on them or have any suggestions. Where are the bolts to level my front end, any pics.
Old Jun 20, 2010 | 08:50 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
They are a vendor on this iste, but I would stick with the OEM Champion copper or iridium. You can twist your torsion bars to level the front end (1/4" per twist),
FF
Old Jun 21, 2010 | 10:00 PM
Big_Wheel's Avatar
Big_Wheel
stick with oem style..and the bolts are on the "keys".. if you follow your torsion bar to the end. you'll see a cross member and on the end of the torsion you'll see the key and bolt.. the picture isnt the best but it gives you an idea.... the bolt goes into that half moon lock he is holding
--also you should lift the front of the vehicle off the ground when you do this--also should get an alignment too
Old Sep 30, 2010 | 03:05 AM
rkalbiar's Avatar
rkalbiar
Any chance of a DIY write up on this?
"You can twist your torsion bars to level the front end (1/4" per twist)," <--- is a 'twist' one full rotation?
