2nd Gen Durango 2004 - 2009
Gas Cap issue
Old Jul 15, 2010 | 02:36 AM
tbroumley's Avatar
tbroumley
Default Gas Cap issue
So I got the infamous Gascap warning on my dash. I went and bought a new one, and replaced it. I did the on/offx3 test and NO codes popped up. I didn't get around to resetting the code.
So I checked it today (my wife drives it) and the engine light was on. I got the following code:
P0457 EVAP Emission Sys Leak Detected (fuel cap loose/off)
What do I need to do? It's got a brand new cap. Could there be something wrong with the filler neck or something?
FYI, it's an 07 with the 4.7 v8.
Old Jul 15, 2010 | 07:27 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Try disconnecting the negative terminal on the battery for a few minutes to reset the system,
FF
Old Jul 18, 2010 | 04:19 PM
unclegoose's Avatar
unclegoose
I got my code to go off and truck to pass inspection by filling around the o-ring in the gas cap with grease.
My gas cap just doesn't seem to fit tight enough anymore. I bought 4 new gas caps trying to get one that would stop the code.
Old Jul 22, 2010 | 03:16 AM
tbroumley's Avatar
tbroumley
Okay, sorry for the delay with the reply. I unhooked the battery and reset the system. It went away...
for one week.
Got home tonight and have the gascap code and now a P0456. That one is a small leak detected. Should I try another gascap? Should I try some grease on the oring? It's REALLY hot here this time of year (AZ). Could that make a difference?
Or should I break down and take it to a mechanic?
Old Jul 24, 2010 | 04:30 PM
Big_Wheel's Avatar
Big_Wheel
try the grease trick, and then see if that works. and then if it does go out and get a new gas cap
Old Jul 28, 2010 | 08:36 PM
tbroumley's Avatar
tbroumley
Okay, now I'm getting the code P0440 which is evap system perf I believe. We've also been noticing a MUCH larger amount of condensation under the durango than what we are used to. Pretty much EVERY time we drive it or move it. Could those be related?
