Indicator Lights
Indicator Lights
The backstory before the issue.
Took Durango (2005 4x4 Hemi) to Wal-Mart to have the tires rotated and balanced. When they put it on the lift, they used some blocks that they put on the cross member. This ended up bending the cross member and the torsion bolt on each side popped out. They obviously had no clue what caused that to happen and ended up paying for the tow and mechanic work to have it fixed. I was even able to get the mechanic to even out the Durango some with the torsion bolts on Wal-Mart's dime.
I drove it home Friday and then out to dinner the next night and everything seemed fine with it, putting about 150 miles on it. Sunday I get in it and before even putting the key in, the 4LOCK, 4LO, and SVC 4WD are all on. Those lights just stay on even after driving and turning the vehicle off. The Durango still drives fine an makes no odd sounds.
Anyone ever hear of this or experience it?
feedback
This juggaloword@yahoo.com
I had the same problem with my moms durrango just unhook your battery then wait 5 minutes then hook it back up if it still stays on then take it in to the shop
