2nd Gen Durango 2004 - 2009
04 5.7L 13k miles, won´t start, fuel pump?
Old Aug 23, 2010 | 07:20 PM
oznext's Avatar
oznext
Default 04 5.7L 130k miles, won´t start, fuel pump?
(Sorry 130K miles)
Hi! there, i was scared when comming back from the groceries my durango did not start, it was like start and imediatly shutted off, i tried start and gas pedal...the same;
after a few mins of trying and panicking, it started, that was last week, never happened again (since)...
Should i replace the fuel pump, are they likely to fail?..
Will apreciate any comment regarding this..
Old Aug 23, 2010 | 07:42 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
With the car off, turn the ignition to the first (accessories) position. You should hear a mechanical 'humming' and that will be your fuel pump turning on. I would test the battery and then the alternator,
FF
Old Aug 24, 2010 | 10:46 AM
oznext's Avatar
oznext
Thankyou, alt and battery tested O.K. @ autozone , when it failed did not had the chance to heard the sound, it has not failed since then.....
Question is.....130kmiles, should i change the pump? do they fail often in this suv´s?....
Old Aug 24, 2010 | 10:55 AM
1969CoronetR/T
vaffanculo
A tune-up with new plugs and cleaning the throttle body may help,
FF
Old Aug 25, 2010 | 06:18 PM
n8ech's Avatar
n8ech
OZ:
Many times when a fuel pump fails, the car will not run at all. There are also times when it will start and run, but not very well.
If yours seems to be working ok now, your fuel pump is probably fine. I would however get your battery load tested, and if it is the original one or newer but tests flaky in the least bit replace it.
As mentioned, if your plugs have more than 50,000 miles on them new plugs won't hurt things either.
Don
Old Aug 26, 2010 | 12:46 PM
oznext's Avatar
oznext
Thankyou guys, i will do complete maintenance of the durango, if you have in hand the fluids grade ond or specs i don´t trust the guys at autozone or kragen they used to get you wrong items ....
Old Aug 26, 2010 | 02:36 PM
1969CoronetR/T
vaffanculo
The FAQ has the fluid capacities that I think n8ech compliled,
FF
