2nd Gen Durango 2004 - 2009
Heater motor noise on '04
Old Nov 14, 2010 | 09:46 AM
sethjamto's Avatar
sethjamto
Originally Posted by sethjamto
Brought mine to the dealer today and they found a cracked vacuum hose in the eng compartment. It is the hose that comes off of the air filter box, runs around the engine and towards the back by the firewall. It then T's to the right and left. On the left (passenger side) is where the split was. They wanted something crazy like a $100 to fix it. I will replace the hose myself for a few cents by cropping out the bad part and splicing in a new hose piece. The mechanic said this would work perfectly.
I'll let you know when I do it and if it works. Right now I'm in the middle of replacing the front driver's side hub assembly......
Okay....I fixed the cracked hose, but the noise is STILL there...... ugh!!
Old Nov 14, 2010 | 02:47 PM
IndyDurango's Avatar
IndyDurango
Personally, didn't think that was it. I was surprised with that as the (supposed) culprit.
IndyD
Old Feb 28, 2011 | 04:00 PM
hottyriyady's Avatar
hottyriyady
Sethjamto,
I just notice the same noise with my 05 Durango but mine comes on when the AC is turned on or off.
I have an oil change due soon so I'll check then but if you have an update with yours, would love to hear it.
