2nd Gen Durango 2004 - 2009
carrier bolt torques
Old Nov 7, 2010 | 09:50 PM
birdie_76's Avatar
birdie_76
Default carrier bolt torques
i have a 04 durango with 9.25 rearend. i am replaceing the bearings. does anyone know the torque for the 4 carrier retaining bolts?
Old Nov 7, 2010 | 11:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
REAR AXLE - 9 1/4
AXLE DESCRIPTION SPECIFICATION
Axle Ratio 3.55, 3.92
Differential Case Flange Runout 0.076 mm (0.003 in.)
Differential Case Clearance 0.12 mm (0.005 in.)
Ring Gear Diameter 235 mm (9.25 in.)
Ring Gear Backlash 0.12 - 0.20 mm (0.005 - 0.008 in.)
Ring Gear Runout 0.12 mm (0.005 in.)
Pinion Torque To Rotate - Original Bearings 1 - 2.2 N·m (10 - 20 in. lbs.)
Pinion Torque To Rotate - New Bearings 1.7 - 4 N·m (15 - 35 in. lbs.)
Fluid Level - From Bottom of Fill Hole 31 mm (1 5/8 in.) ± 6 mm (1/4 in.)
TORQUE DESCRIPTION N·m Ft. Lbs. In. Lbs.
Differential Cover Bolts 44 32 -
Bearing Cap Bolts 135 100 -
Ring Gear Bolts 157 115 -
Pinion Nut Minimum 285 210 -
Adjuster Lock Screw 10 - 95
Pinion Mate Shaft Lock Screw 25 - 220
Bell Crank Bolt 217 160 -
