2nd Gen Durango 2004 - 2009
2006 Durango - power loss/engine light on
Old Jan 8, 2011 | 01:18 PM
lah722's Avatar
lah722
Default 2006 Durango - power loss/engine light on
I was sitting at a red light and when it turned green for me to start my turn, my Durango only crawled like it had very little power. Once I got rolling, however, it seemed to pick up more power along the way. The engine light is on too. After driving it like this for about 15 minutes I found that while the light has stayed on, the power seems to be somewhat back to normal for now but I expect it will happen again. Has anybody experienced this same thing and if so, what needed to be looked at and fixed? It's not the hemi engine...I think it is a 4.7L. Thanks for any suggestions.
Old Jan 8, 2011 | 01:53 PM
bwdakrt's Avatar
bwdakrt
Take it by AutoZone and have them read the code and then you'll know where to start looking. At this point there could be a lot of different things causing it.
Old Jan 8, 2011 | 03:18 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You can pull the codes by turning the car from off to on (not run) three times and on the third time the odometer will flash a 'P---' (three numbers) or 'done'
FF
Old Jan 8, 2011 | 07:29 PM
IndyDurango's Avatar
IndyDurango
+3. We need the codes to be able to tell you anything.
IndyD
