2nd Gen Durango 2004 - 2009
2005 durango oil pressure light
Old Jan 11, 2011 | 06:55 PM
jimzcool2's Avatar
jimzcool2
Default 2005 durango oil pressure light
Oil pressure light came on and stayed on ,had towed.They replaced the oil pump. I was wondering now apon startup oil light stays on ,but if i shutdown and startup again it does go out.any ideas?
Old Jan 11, 2011 | 07:19 PM
WhiteWidow00's Avatar
WhiteWidow00
Belongs in the 2nd gen Durango section...
Old Jan 11, 2011 | 07:47 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you are correct, ill move it for you
Old Jan 11, 2011 | 10:20 PM
jasonw's Avatar
jasonw
Site Moderator
Who installed the oil pump for you? Local shop, $tealership? I'd take it back to them and make them fix it, since it shouldn't be doing that if it was installed properly.
Old Jan 22, 2011 | 08:15 PM
n8ech's Avatar
n8ech
Jim:
WOW.....Did they take any steps to verify that there was no oil pressure? The 04-05 Hemi engines were plagued by faulty oil sending units. I replaced the sender on my 04 not long ago for operating the same way.
The first start of the day, light would stay on. If you shut it off and restarted, light would be off. Subsequent starts for that day light would function normally.
How many miles on your D?
I agree that whatever shop replaced the pump owes you further work to finish the job. My bet is that they will find that the oil pump was ok to start with,and that they should have started with the $22 sender to start with.
Don
