2nd Gen Durango 2004 - 2009
Can't get check engine light off to pass inspection!
Old Feb 2, 2011 | 09:28 AM
MARKTW's Avatar
MARKTW
Default Can't get check engine light off to pass inspection!
I have a P2308 code that I can't figure out?
I have all new spark plugs, new ignition coils and new plug wires and the code won't clear!
I hooked a test light up to the cable supplying coil #3 and nothing all the other cables have a flashing light when tested.
So searching around it seems to be either the wire to coil three which is almost immposible to trace (for me anyway) or a bad coil driver in the PCM.
Does anyone know where I can find the PCM in an 04 Durango?
