Normal position for temp gauge for '05 D when running
My '05 D temp gauge remains one slash under middle...even after driving it for 10 min or so early in the morning. Is that normal?
I bought it used and now has 104k km and I see a receipt from the previous owner for a 195 deg thermo.
Am I worried over nothing or should it get checked out?
Thanks in advance.
Thanks in advance.
I am not sure if you have the 5.7 liter Hemi, but mine never goes above 1/4 (from the bottom) with a 180 degree thermostat. I would change the coolant every two years and you should be alright,
FF
FF
HHRY:
A needles width or two under half scale is the norm. My 01 was that way, my 04 is that way, and the 05 we have at work is that way also.
As far as your coolant goes, the factory fill is good for 5 years OR 100k miles. As long as you use the same coolant, an equivalent, you can keep the same interval.
Don
Don
