have a questions
Anything over a certain weight limit (not sure what though) will turn it on as jasonw stated.
Per the manual,
FF
Also, the ORC turns on the AIRBAG warning
light in the instrument cluster for 6 to 8 seconds
for a self-check when the ignition is first turned
on. After the self-check, the AIRBAG warning
light will turn off. If the ORC detects a malfunction in any
part of the system, it turns on the AIRBAG warning light
either momentarily or continuously. A single chime will
sound if the light comes on again after initial start up.light in the instrument cluster for 6 to 8 seconds
Per the manual,
FF
I found that in there now. I guess my sensor is broken because my airbag light is always on and the airbag indicator always says airbag off even when someone is sitting in that seat. thanks
