2nd Gen Durango 2004 - 2009
Rear Differential Oil Change?
Old Jul 1, 2005 | 04:11 PM
  #21
Last Of The R/Ts's Avatar
Last Of The R/Ts
Default RE: Rear Differential Oil Change?
Yeah well whatever, this is getting really rediculous and it seems like we are just in here arguing to ourselves and not accomplishing anything. It's really getting old so peace be with you son. [sm=closed.gif]
Old Jul 1, 2005 | 04:46 PM
  #22
alienyzf's Avatar
alienyzf
Rock on young Jedi. It was a good pissin' contest. [sm=deal.gif]
Old Jul 1, 2005 | 05:54 PM
  #23
Last Of The R/Ts
Sure was! [sm=bicker.gif]
Old Jul 7, 2005 | 11:46 PM
  #24
tenntech's Avatar
tenntech
Just remove the large bolt in the center of diff. cover, pull links out of the way, and service it like any other diff.. The center bolt is pretty tight (I think 160 ft. lbs.). 75W-140 synthetic fluid should be used and if vehicle is equipped with limited slip it requires an additive. No gasket is available, just use axle rtv.
**service is recommended every 15,000.
Old Aug 8, 2012 | 03:51 PM
  #25
schwede133's Avatar
schwede133
Hello,
have I to jack the car or can I remove the large bolt without jacking?
Thanks
Matthias
Old Aug 9, 2012 | 09:44 PM
  #26
kmhexplus's Avatar
kmhexplus
I had mine done for about 39.99 at a oil change place.
Old Nov 9, 2013 | 11:19 AM
  #27
kgrdnr's Avatar
kgrdnr
2001 3500 type gear oil?
Old Apr 14, 2019 | 07:20 PM
  #28
Superbee68's Avatar
Superbee68
250,000 on my Dodge, never changed the diff, transfer case, or tranny fluid. Still running.
Old May 28, 2019 | 09:16 PM
  #29
birkato's Avatar
birkato
I have a video I recorded on how to change both the front and rear differential fluid as well as the transfer case fluid if it is of any help to you. It is sort of a pain to do but not difficult if you have basic mechanical skills. A lift would make the job much easier!
Here is the video for the rear differential fluid change:
