2nd Gen Durango 2004 - 2009
Code P2175 Throttle actuator Ctl Sys - Low airflow detected
Old Mar 13, 2011 | 05:56 PM
Still Learning's Avatar
Still Learning
Default Code P2175 Throttle actuator Ctl Sys - Low airflow detected
I have a 04 D limited with 5.7 4wd. Keep getting a code showing low airflow detected. When the code is thrown, it will reset after the ignition is turned off and on, vehicle resumes normal operation. Where is the sensor located? Any help would be appreciated. Thanks
Old Mar 13, 2011 | 07:17 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Clean the throttle body and intake and it should clear the code. Seafoam is a good cleaner,
FF
Old Mar 13, 2011 | 10:45 PM
Still Learning
Thanks for the suggestion, I will give it a try. I am not familiar with the cleaner. Is it a spray, liquid or how is it applied. Could use some help in what all has got to be removed to get to the throttle body. I am definately an ametaur but willing.
Old Mar 14, 2011 | 07:29 AM
1969CoronetR/T
vaffanculo
Just follow the the air cleaner up to the engine as the air intake runs into the throttle body. You may have to take the plastic engine cap off,
FF
Old Mar 14, 2011 | 10:37 AM
Still Learning
Thanks for the help, will get it done asap and get back to you.
Have previously replaced the air filter. Cleaned the throttle body today. It was filthy. Will put it on the road and see if this helps.
Old Jun 18, 2011 | 01:50 AM
ryan rol's Avatar
ryan rol
i know it has been 3 months, but did you get results from cleaning it?
Old Sep 11, 2013 | 08:37 PM
JenniferThomas's Avatar
JenniferThomas
I have cleaned and replaced throttle body still wont start now what?
Cleaned throttle body didnt work then replaced it still wont start what now?
