2nd Gen Durango 2004 - 2009
2004 durango
Old May 13, 2011 | 08:47 PM
hhjh444hj's Avatar
hhjh444hj
Default 2004 durango
How can i make it 4x4 on demand instead of awd?
Old May 15, 2011 | 06:02 PM
IndyDurango's Avatar
IndyDurango
If it is AWD, it is AWD and you can't. That is what the "A" stands for... ALL-TIME.
If it isn't AWD and instead just a 4x4, often there is 2x4 selectivity.
IndyDurango
Old May 15, 2011 | 08:57 PM
n8ech's Avatar
n8ech
HHJH:
As Indy stated, your D is equipped with an AWD T case. Might I inquire as to why you would want to make the switch to part time?
If the reason is fuel economy, it has been proven over and over that mpg is affected 1-2 mpg at the most between the part time and AWD systems.
I swapped out the NV233 in my 01 Durango for the AWD 244 case, and on average the mpg drop was 1 mpg or less.
To properly make the change, you would need to install a part time case which was the NV233 for the Gen 1 Durangos.
The T case in your Gen 2 is the NV244.
If you really want RWD for a temporary period, you can do this by removing your front driveshaft and putting the dash switch to the 4lock position.
Don
Old Aug 21, 2011 | 11:52 PM
hhjh444hj's Avatar
hhjh444hj
what modifications will i have to do
Old Aug 22, 2011 | 12:43 AM
jasonw's Avatar
jasonw
Site Moderator
New transfer case, and a bit of wiring. Its not worth it, and the cost will be more than you'll gain from the very slight (maybe 1 MPG) mileage increase.
Old Aug 22, 2011 | 06:26 PM
n8ech's Avatar
n8ech
HHJH:
It might help to know WHY you want to do this? As already stated, MPG gain will be little if any. Part time 4 wheel drive was not a factory options for the Gen 2 D.
If you are wanting to be able to enjoy some rear wheel drive fun, this can be done but we do not know what the long term effects may be.
Don
