2nd Gen Durango 2004 - 2009
2005 Durango AC
Old Jun 6, 2011 | 09:49 PM
Dodgy Rango's Avatar
Dodgy Rango
Default 2005 Durango AC
It blows semi cold air so I thought it was low, I emptied a can of R-134a in it, no effect. During the filling process, it didn't even get cooler inside the cabin.
What could cause that? The compressor seems to be cycling ok.
Old Jun 6, 2011 | 09:56 PM
n8ech's Avatar
n8ech
Dodgy:
Do you have the rear AC, and if so how is that working? Could be a blend door issue inside the heater/AC box under the dash.
When you run the mode selector through its range, does the air switch to the appropriate outlet?
Don
Old Jun 6, 2011 | 10:02 PM
Dodgy Rango
No rear AC
The selectors work when i switch it in the different settings.
I was thinking it might be really low, but 1 can of the blue Ice NASA something R-134a should have at least made the air cooler. It took the whole can.
One thing I haven't checked is if I get some water dripping when I'm idling with the AC full blast.
Old Jun 6, 2011 | 10:09 PM
n8ech's Avatar
n8ech
Dodgy:
I think the next step will be to get some gauges on the system to verify the 134a level, and see what the pressure readings are.
Don
Old Jun 10, 2011 | 12:32 PM
richkatw's Avatar
richkatw
I have a 2005 and have the same problem. I do have rear AC. I was able to put a guage on it and it read that it had the correct amount. what next
Old Jun 19, 2012 | 01:38 PM
comanche1313's Avatar
comanche1313
About the best thing you can do with these 2005 dodge durango's
Last edited by 1969CoronetR/T; Jun 19, 2012 at 01:41 PM. Reason: funny guys first post
Old Jun 21, 2012 | 11:06 PM
JCDurango05's Avatar
JCDurango05
Default A/C
The Expansion valve controls flow to both front and rear evaporator cores. I,ve changed quite a few especially on ones with front and rear a/c. In all cases the rear blowing cold and the front blowing warm typically is what i've experienced.
