2nd Gen Durango 2004 - 2009
AWD MOD Question
Old Jun 16, 2011 | 06:45 AM
buster1104's Avatar
buster1104
Default AWD MOD Question
I have a 2004 AWD Hemi Durango. It's killing me on gas. Can I remove either the front or rear drive shaft without it causing damage to the transfer case? It is a family vehicle at this point so off roading is not an issue.
On a side note the Rear Climate Control only blows cold air. Heat no longer works. Anyone else had this issue?
Old Jun 16, 2011 | 07:40 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
There is a thread in the first generation Durango section about removing the driveshaft and your blend door may need replaced for the heat issue,
FF
Old Jun 16, 2011 | 03:05 PM
IndyDurango's Avatar
IndyDurango
Yes you can. Gain will be minimal at best and not worth the efforts and/or pending damage later. Costs will be higher than just living with it.
The Gen1/Gen2 Durango was never, and never will be, fuel efficient. You are pushing a brick through the air, not a sleek supercar. The Pentastar v6 in the Gen3 is designed to be more fuel-friendly.
IndyD
Old Jun 17, 2011 | 10:59 PM
n8ech's Avatar
n8ech
Buster:
+2 on what Indy said. The only way to keep gas in a Durango other than the gas station is to leave it parked. You will see maybe 1 mpg change if you remove the front driveshaft.
This is because the majority of the 4x4 hardware is still installed and turning. Add to that a 5100 pound curb weight and poor aerdynamics, and you arrive at the window sticker mpg which is 13/18 for the 4.7L and 13/17 for the Hemi.
Don
