2nd Gen Durango 2004 - 2009
fan clutch help
Old Jul 3, 2011 | 06:46 PM
firemedic74's Avatar
firemedic74
Default fan clutch help
Hello all, this is my first post on this forum
I'm looking for some help with a fan clutch on an 04 durango with 4.7L and max cooling.
I've had an overheating problem and have narrowed it down to a bad fan clutch. I initially installed a heavy duty fan clutch and the noise was rediculous, I also noted a significant loss of power on accelleration (felt like I was pulling a boat up a hill... and I'm sure it wasn't just the noise making me think so)
I returned that for a standard duty clutch and the noise was still unacceptable and never seemed to stop.
I've noticed listings for a reverse direction clutch and I don't know how to tell if that is actually the one I need.
Can anyone answer that?
Also, the clutched I bought were Hayden's. Is that the nature of an aftermarket clutch? I'm not sure if it would make a difference to try and find an OEM.
Thanks to anyone that can help out!!!
Old Jul 5, 2011 | 10:21 PM
RangoBruce's Avatar
RangoBruce
Had the same problem with my 05 4.7L 4X4. Ended up doing an electric fan conversion. Used a Chevy HHR electric fan (Auto Zone $65.00) and a DRALE adjustable elcetric fan controller (Ebay $52.00). Conversion was fairly easy usyng the original fan shroud. took about 4 hours. works great I set the fan to come on @ 200F and it goes off 10F below set temp. also wired to come on with A/C.
Old Jul 6, 2011 | 11:17 PM
firemedic74
That is probably what I'll end up doing, thanks for your input and advice!
