2nd Gen Durango 2004 - 2009
Head unit swap question
Old Jul 29, 2011 | 09:46 AM
WarlockLord's Avatar
WarlockLord
Default Head unit swap question
I have an 04 Durango. I don't believe it has an infinity system. It has the woodgrain bezel with the factory radio in it, with the two rotary ***** that half of each **** protrudes into the woodgrain bezel. Aside from the *****, it appears to be a double din sized opening. Can I swap a double din head unit into it until I can find a bezel replacement that eliminates the 2 half circles for the *****? Do I need a mounting kit or will whats there have the holes to mount an after double din unit?
Old Jul 30, 2011 | 01:03 PM
tinmanwpk's Avatar
tinmanwpk
I can't answer your question directly but I can point you in the right direction I hope. Try checking out www.crutchfield.com They are pretty good about information, and if you need to you can call them and talk with a service tech.
